2004 XC90, Dashboard out, what else should be replaced?
Old Feb 10, 2019 | 03:38 PM
eapowers64's Avatar
Default 2004 XC90, Dashboard out, what else should be replaced?
Hi everyone, I just purchased a 2004 XC90 2.5T FWD with 135,000 miles for next to nothing. It had the typical water leakage into the cabin that festered and did a decent amount of damage - carpets, yaw rate sensor, A pillar upholstery, etc. I have pulled everything from the interior (seats, seat mounts, carpets, foam blocks, etc.) The first big task is to make this beast watertight. I am going to replace the foam seal that goes between the A/C inlet plenum underneath the cowling and the blower motor as it is crumbling into the blower and I have heard that water leaking through that area can be an issue. As far as I can tell, this requires pulling the dashboard to access correctly which is not that big of a deal considering that everything else is out of the car and there is a lot of room to move around! I have two questions. 1) am I correct that I should pull the dashboard to do this? 2) is there anything else that I should replace as a preventative measure once I have the dashboard out? As far as I know, everything works but the car is getting on in years.
Thanks!
Eric
Old Feb 12, 2019 | 11:24 AM
not sure if your dash cluster has backlight bulbs but I'd replace any small bulbs in the gauge cluster when you have easy access.
Old Feb 12, 2019 | 11:27 AM
eapowers64's Avatar
Good thought!
blakeboone42
Jan 10, 2018 11:16 PM
jezyen
Sep 2, 2017 07:40 AM
Chapster2009
Jan 22, 2016 05:41 PM
Bradward
Apr 7, 2011 10:04 PM
xc902004
Nov 27, 2007 05:23 AM
