2004 XC90 HID headlight failure
Old Jul 28, 2010 | 04:00 PM
lambshark's Avatar
Default 2004 XC90 HID headlight failure
The headlights on our 2004 XC90 T6 failed completely while on a mountain road. Has ayone else had this problem and how was it repaired. The dealer is telling me that I need a $650 module and the labor/download is another $500. The message center indicated low beam failure but I had NO headlights at all.
Any suggestions?
Old Jul 28, 2010 | 05:14 PM
Dealer_Tech's Avatar
It can be the C.E.M. and/or the headlight ballast. There are many other things but these are the two that I run into. The CEM is very expensive and does require a download since it is the module that communicates with everything. Not the first time I have seen it.
Old Jul 29, 2010 | 12:44 AM
Legendsecko87's Avatar
I would think the ballast. Swap bulbs to see if that works.
Old Oct 8, 2010 | 04:15 PM
edieo31's Avatar
Default Any luck?
checking to see how you resolved this issue. I've been experiencing the same problem since July. Like with you, everything has been checked and the bulb replaced with no luck. I'm not looking forward to dropping $600+ for a module especially since i have an oxygen sensor that also needs to be replaced.
Old Oct 22, 2010 | 05:29 PM
GM Man's Avatar
Is there anyway to test to see if its the C.E.M. or the ballast? My wifes 2004 XC90 lost the low beam, and I tried two different bulbs today, and neither one of them worked.
04XC90T6AWD
Jun 13, 2011 04:25 PM
drew.johnson81
May 1, 2011 07:48 PM
gmanropley
Nov 12, 2010 12:08 PM
speedracer67
Jul 16, 2010 10:12 AM
volvodadvt
Apr 11, 2010 10:08 PM
