2005 XC90 Bsttery drain issues
Old Feb 18, 2019 | 09:58 PM
Harry Paratestis's Avatar
Default 2005 XC90 Bsttery drain issues
something is draining the battery on my 2005 xc90. If the car sits a day or 2 it will not start. I replaced the battery and thought I had the problem solved, I was wrong. The problem is more prevalent in the cold weather. Nothing more annoying then going out to start the car and its dead.
Old Feb 19, 2019 | 08:44 AM
next step is to use a meter to measure the current draw to the battery with the engine off. Start pulling fuses until you see the current draw drop, then research what's on that circuit. Typical causes are things like vanity lights / glove box lights that are not switching off so I'd start by taking a look around. A small light can drain a battery in two days.
Old Feb 22, 2019 | 01:33 PM
CROSSING COUNTRIES's Avatar
If you have a SAT Radio, that could be the issue...
guest30295
Jan 4, 2021 05:41 PM
barbist
Aug 27, 2018 11:35 AM
bonedoggie
Jan 2, 2017 07:20 PM
Italo N Christi Dresda
Jul 24, 2012 11:20 AM
stupid car
Jan 19, 2009 09:01 PM
