2006 xc90 4.4 codes p0171 p0174
Old Jun 12, 2019 | 05:38 PM
green2man0's Avatar
Default 2006 xc90 4.4 codes p0171 p0174
So I'm still trying to figure out my recent code issue. The CEL comes on and off intermittently. This started after the intake hose somehow came off the airbox and put the car into limp mode. I reattached the hose, reset the ecu, and degreased the engine bay. Everything was good for a couple of days. It still seems to start, run, and drive normal. Then the CEL came on (occasionally it goes out and then turns back on). I just got my new code scanner and checked it this afternoon. P0171 P0174 (right and left bank lean) (no other codes). I replaced the fuel filter and gas cap this afternoon. I also checked for vacuum leaks and didn't find any. I have a spare MAF sensor in my parts stock. I'll try that tomorrow if the cap and filter don't do the trick. Is there anything else I should check or try?
Old Jun 12, 2019 | 06:25 PM
when you checked for vacuum leaks did you just do a visual or did you use a smoke machine? Any exhaust leak sounds going on?
Old Jun 12, 2019 | 07:25 PM
green2man0's Avatar
Sprayed brake clean around all the vacuum lines with the engine running and around the intake. Idle stayed smooth without and blips in rpm. No exhaust leaks so I don't think it's gonna be the 02 sensors.
Old Jun 14, 2019 | 03:19 PM
green2man0's Avatar
Same code keep coming up. So far I've replaced the fuel cap, fuel filter, maf sensor, cleaned the throttle body, and checked for vacuum leaks (none found). What's next...check PCV??? EVAP canisters?
Old Sep 27, 2019 | 11:31 PM
Jared4178's Avatar
Were you able to resolve the issue. I am fighting something similar. I just replaced the PCV as it had failed. I cleared the CEL and it’s back in with the same codes. What was your solution?
Helga_940
Jul 24, 2017 08:30 AM
Perrin
Sep 29, 2015 01:43 PM
teamcrossworks
Jul 14, 2011 11:19 AM
gigi55
Oct 27, 2010 11:34 AM
cbstv
Dec 7, 2009 05:09 PM
