2010 XC90 AWD Oil Change Questions
Hi Folks,
I just bought a 2010 XC90 3.2 AWD. I have sched maint covered by Volvo for 60k, however I'd like to have a break-in oil change done by a local shop (they have done great work for me on other cars i've owned)
Few questions...
- AutoZone only carried an STP S10415 filter for the car. Has anyone used this filter? Any issues?
- Is there anything I should know about changing the oil on this car? I've heard about specific order (remove oil filter first) as well as something about a special tool to remove the filter housing. Is this needed?
Thanks in advance.
Few questions...
Thanks in advance.
the tools needed are,
filter tool 36mm socket, yes, but just loosen all the way, dont remove yet.
belly pan 7 bolts, 10mm socket
drain plug, 17mm socket
GET THE DRAIN PLUG CRUSH WASHER, AND WHILE YOUR THERE, GET THE FILTER AND O-RING. its like the kit.
