AC Electrical Issue, perhaps ECU related?
Old May 18, 2022 | 04:05 PM
Altercall's Avatar
Default AC Electrical Issue, perhaps ECU related?
I just changed out the compressor, condenser coils, evaporator/dryer, and front and rear expansion valves on my wife’s 2010 XC90 3.2L. The old compressor worked, but not well (read 65PSI on low end before I could get ANY cooling in the car) but I needed new condenser coils, so I changed everything out. When I hooked up the new compressor, the clutch wouldn’t engage. The AC shop hooked it up to the positive terminal to charge the system.
I pulled my AC clutch relay and jumped the switch and the clutch will engage when I jump it. I put a voltmeter on it and I’m getting wired readings. It’s a 4 prong relay (2 for the switch, 1 for the + and one for neutral/ground). When I checked + to frame I get 13.5V. When I go + to neutral/ground I get 3.4V. And neutral/ground to frame I get 3.4V.
next I followed the neutral/ground wire off the terminal and it leads to the ECU.
So… do I have an ECU issue, or is the ECU intentionally sending voltage to the relay to keep the switch from engaging? If it’s intentionally sending voltage, why? How do I figure out what’s going on?
Old Jun 14, 2022 | 11:19 AM
Altercall's Avatar
Just to close this out, I had forgotten to hook back up my high pressure sensor. Had to go to a Volvo mechanic to pull the code and found the harness unplugged.
Robert3324
Jan 25, 2022 10:32 AM
5mall5nail5
Jun 11, 2020 09:34 PM
june82000
2001-2013 model year V70
Mar 21, 2013 02:11 PM
june82000
Mar 20, 2013 06:35 PM
A_aron
Jul 23, 2009 07:21 PM
