Anti Skid service required question
1st time here. I have a 2008 xc90 with 191,000 miles. Runs great. Last night the Anti skid service required msg came on. In my limited research it can either be the Yaw Rate Sensor part # 31110063 located under the passenger seat OR the steering angle sensor in the steering wheel, part # 31264468.
How do I determine which needs replacement? Any input is appreciated. Thanks
ABS control units fail also. Many companies repair those -
You scan the car with a compatible scanner, From those codes (if any) Identify what component/s might be causing your message. Then develop a reasonable/rational/logical diagnostic procedure to determine what part (if any) is bad. Much cheaper and less frustrating than guess, replace, guess, replace, and repeat.
