Anti-Skid Service Required, What is that!!!
Old Mar 8, 2016 | 02:29 PM
rudva's Avatar
Default Anti-Skid Service Required, What is that!!!
My XC90 shows me the Anti-Skid Service Required message, what is that???
I don't found any information in the owner manual. Then before go to the dealer service and pay for an astronomical price, I prefer to ask if I can found DIY information.
Old Mar 15, 2016 | 10:04 PM
schumicat's Avatar
there are many many posts on this you can find with a search. a couple of common causes.
Old Mar 19, 2016 | 08:03 PM
rudva's Avatar
Default Really, where?
Really?
I search first but don't found any, do you have the links?
Old Mar 22, 2016 | 09:27 AM
schumicat's Avatar
in the menu bar select search...select advanced search....in keywords box type "anti skid service required" and under search in forums select xc90. then run the search. you will find many results. there are a few common causes. the only way to know for sure is to have it scanned with volvo specific scan tool at the dealer or you can buy it on eBay for couple hundred bucks. if the problem appears when you park with the wheels turned sharply it is probably the clockspring in the steering wheel.
Old Mar 25, 2016 | 09:51 AM
Reynold Gayahpersad's Avatar
Default Anti skid service required. YAW SENSOR
the yaw sensor manages the vehicle skid to prevent fish tailing etc on slippery surface. It's usually good for 8 to 10 years. Some are located under the stereo amp which is under the front Right passenger's seat of the xc90 like in the 2004 model.location may vary in other years model.
Last edited by Reynold Gayahpersad; Mar 25, 2016 at 09:55 AM. Reason: Exact location
Old Mar 31, 2016 | 06:45 PM
rudva's Avatar
Default Now is off
Ater change the tires and the aligment and balance service, the anti-skid alarm turns off. Sometimes in the morning it hears like is activated, I'm going to change the sensor in the future.
Old Jun 26, 2016 | 06:24 PM
hankxc90's Avatar
Default All data diy bulletin on this error
The info from alldata is below, sounds like a software issue. Any thoughts? Probably why some dealers have told posters they need a new DIM .. But sounds like volvo can upload the update.
TITLE: Yaw rate sensor, BCM-C006364 or BCM-0121
REF NO: TJ 28031
ISSUING DEPARTMENT: Technical Service
CAR MARKET: United States and Canada
PARTNER: 3 US 7510 Volvo Cars North America
FUNC GROUP: 5939
FUNC DESC: Miscellaneous
ISSUE DATE:
YEAR MONTH DAY
2013 07 22
"Right first time in Time"
Vehicle Type
CSC Customer Symptom Codes
DTC Diagnostic Trouble Codes
Text
DSTC = Dynamic Stability and Traction Control
BCM = Brake Control Module
DESCRIPTION:
Anti-skid warning lamp with DSTC warning message may be set after a few minutes driving after system start up, with DTC BCM-C006364 or BCM-0121.
The symptoms indicate that there could be a plausibility problem with the alignment of the Steering angle sensor (SAS) or a faulty Wheel alignment, however the DTC could occur if both SAS alignment and wheel alignment are within specifications due to algorithm specifications in BCM software.
PRODUCT MODIFICATION:
A new BCM software was released 2013 week 22 in production and is also available to upgrade existing vehicles from model year 2006.
MATERIAL RETURN:
No.
VEHICLE REPORT:
Yes, please submit a Vehicle Report if the service solution described in this TJ has no effect. Use concern area "Vehicle Report", sub concern area "Support Not Needed", and function group 5939.
SERVICE:
Order and download BCM Upgrade software, PN 30677015.
Volvo Standard Times Guide (VSTG) OPERATION NUMBER:
36004-2 Software control module downloading See VSTG
Old Mar 18, 2021 | 10:46 PM
redtesta89's Avatar
Default search
Did the exact search as you told Rudva and came up with zero search results based on " anti skid service required" and selected xc90. Fyi.
congerali
Mar 1, 2021 09:08 AM
blckwlfny1
May 1, 2014 06:04 PM
birdiegirl54
Sep 3, 2010 09:03 AM
durch
May 10, 2009 03:17 AM
chrissygm
Sep 30, 2008 05:53 PM
