ATF quantity
Hi,
I have just got a Volvo xc90 with the d5 185) engine (UK), 2007. I want to change the ATF and cannot find out how much oil I need for this. The plan is just to drain and fill. I have tried searching google and several forums, while there are lots of 'do it l like this' posts no one seems to mention amounts. Thanks for any advice. |
Specifications, including the correct fluid type (ie JWS 3309) can be found in the owners manual. if you have the TF-80SC transmission (6 speed ) then its about 7.4 quarts. Note that when you do a drain/fill only about 60% comes out. you can use the bucket method to measure the amount drained then feed back in the same amount to ensure you don't under/over fill.
Thanks
Originally Posted by mt6127
(Post 459863)
