ATF quantity
Old May 15, 2018 | 11:29 AM
cobminor's Avatar
Default ATF quantity
Hi,
I have just got a Volvo xc90 with the d5 185) engine (UK), 2007. I want to change the ATF and cannot find out how much oil I need for this. The plan is just to drain and fill. I have tried searching google and several forums, while there are lots of 'do it l like this' posts no one seems to mention amounts. Thanks for any advice.
Old May 15, 2018 | 07:33 PM
Specifications, including the correct fluid type (ie JWS 3309) can be found in the owners manual. if you have the TF-80SC transmission (6 speed ) then its about 7.4 quarts. Note that when you do a drain/fill only about 60% comes out. you can use the bucket method to measure the amount drained then feed back in the same amount to ensure you don't under/over fill.
Old May 16, 2018 | 01:29 AM
cobminor's Avatar
Default Thanks
Thanks for that, that is more than I have so far.
robert213
Mar 16, 2012 12:29 PM
Dr. Mordo
Apr 6, 2008 08:06 PM
ovlov13
Nov 4, 2006 08:35 PM
pawel
Sep 19, 2006 08:38 PM
POR2
Jun 17, 2005 07:34 PM
