CEL: Code P0171 - need help to diagnose further
Old Jan 7, 2023 | 08:23 PM
stevehifi's Avatar
Default CEL: Code P0171 - need help to diagnose further
Hi Guys,
I have a 2017 XC90 T8 with 60k miles and have recently gotten a code p0171 showing 'System Too Lean Bank 1'. I have checked the following:
-air filter housing nice and tight
-no visible issue with intake system or any plumbing
-no 'whistling' or strange rpm behavior (normal idle at 800rpm)
-no issues with oil leaks or oil consumption
OBD2 scanner showing O2 Bank 1 sensor voltages at around 0.95V
-car has half a tank of gas but only range of 80miles (so probably running rich)
-I can smell a strong fuel smell at idle (so again car running rich)
From what I've ready on the forums/internet problem could be related to:
-oil trap clogged or problematic (although i don't hear a whistle or issue with idle)
-vaccum leak (don't hear anything abnormal and fuel trim doesn't dip when idle raised)
-idle issues - rough or variable (no issues here, car idles fine)
-O2 sensor faulty (Not sure how to tell if the O2 sensor is faulty: any suggestions on how to tell?)
Car seems to drive normal in all modes (actually just came back from long trip to Vegas with no issues) CEL turned on a couple days after.
Looking for some feedback on people that came across this and suggestions to try.
Thanks,
Steve
Old Jan 8, 2023 | 10:32 PM
code says the o2 sensor is reading too much oxygen ( ie not enough fuel to use up the alotted air). Normally I'd start with testing for an intake air leak (hoses/tubing/pcv/MAF etc) including an inspection and possibly a smoke test but since you noted you smell gas suggests there's something going on with the fuel delivery system that needs to be checked out - ie erratic fuel pressure or possibly a leaky line for a fuel injector issue/injector seal etc. When you say you have an 80 mile range - what was the range before this issue cropped up?
Old Jan 8, 2023 | 11:08 PM
stevehifi's Avatar
-All parts of the intake were checked (hoses/tubing/pcv/MAF)
-PCV is not whistling, and the idle is normal
Yes the engine is running rich (computer is compensating for the lean condition by injecting more fuel)
-The range was normal before the issue cropped up (about 150-200mile on a half tank)
-As I said now it's at 80miles on half a tank so it looks like the computer is calculating that more fuel is needed and gas mileage is impacted
One thing I didn't mention is that I did the following maintenance on Dec 18th (about 2 weeks before the problem happened):
-cabin filter change
-engine air filter change
-spark plug change
-oil change
But the car ran perfectly in those 2 weeks and we did a big trip (1k miles) over the holidays too without issue
Very odd.. hoping it's maybe a bad 02 sensor or something. Have appointment at dealer on tuesday .. I guess we'll see.
Old Jan 9, 2023 | 09:54 AM
usually a major fail of the front o2 sensor (aka the lamda sensor) will set off a CEL. Similarly issues with spark plugs/coils - I'd also expect a CEL but its possible for something odd like a plug not being fully tightened (easy enough to check). Still I'd be concerned of the fuel smell - to me that suggests a leak somewhere. Good luck and post up how you make out.
Old Jan 9, 2023 | 12:54 PM
stevehifi's Avatar
yes its very odd, I've done work on european cars for a long time and this situation is very unusual. I don't really see why a plug change could of possibly caused this issue (maybe it's a coincidence).
One thing to note, the plugs were really seized into the engine so I did have to use some special lubricant (similar to WD40) in the chamber around the plug to help loosen them up (there were alot of carbon deposits). So i'm not sure if the lubricant got introduced
into the chamber (cylinder area) and caused an issue (fouled something or a sensor) but usually that stuff burns off quickly.
The use of the lubricant was unavoidable as breaking a plug while trying to untighten it would of been a major issue for me and a very costly repair.
Old Jan 9, 2023 | 03:00 PM
I'd probably pull the new plugs out just to have a look to see what the electrodes and gaps look like and whether there's any staining on the outside (metal and porcelin) that would suggest a poor seal into the head.
Old Jan 10, 2023 | 04:44 PM
stevehifi's Avatar
dealer did a smoke test and it looks like its the seals on the supercharger. They will have to replace them and they said they might replace the O2 sensor as well.
will let you know when the final repair is finished
Old Jan 17, 2023 | 05:28 PM
stevehifi's Avatar
Final analysis:
-Front O2 sensor replaced
-Seals on supercharger replaced
Also they did find that one of the engine mounts was bad during the inspection and replaced that.
Looks like the car is fine now.
Old Jun 1, 2023 | 07:27 AM
Volvoeu's Avatar
Default Hi
Hi Steve,
I’m currently facing the same problem with my car (same as your car, same year, same miles, etc.)
Following a smoke test at the dealership, they changed the seals as well, and one of the engine mounts!
I did a 1k mile trip afterwards with no problem. Back home, 1 week after the long trip, I have a CEL with the same p0171 code (no impact at all on the driving).
You said that the dealership changed the front o2 sensor as well. Which isn’t my case.
Could you please tell me if your problem was definitely fixed since that date?
Many thanks.
Philippe
Originally Posted by stevehifi
Hi Guys,
Thanks,
Steve
Old Jun 1, 2023 | 10:54 AM
stevehifi's Avatar
The repair involved changing:
-the front O2 sensor
-Supercharger seals
Since then no issues
Old Jun 1, 2023 | 11:27 AM
Volvoeu's Avatar
Thank you for your reply!
do you know by any chance what made them change the O2 sensor? Did you have weird o2 voltage values or something else?
-Supercharger seals
Old Sep 8, 2023 | 06:02 PM
Jwarre2's Avatar
-Supercharger seals
Do you happen to know what supercharger seals were replaced?
Old Jun 26, 2024 | 08:54 AM
Jenniferp's Avatar
I’m having similar issues but not the strong fuel smell. My mechanic has done several smoke tests and only revealed a leak in the PSV and replaced it along with the oil trap. Besides the code, I don’t have any other signs of a problem but this code is a mystery. The mechanic is now suggesting it’s maybe an issue with a leak in the supercharger and a repair will be a minimum of $5k. I keep asking them to check the 02 sensor . This code has been going on periodically for 3 years. It’s so frustrating. Can I ask how much it was for you to replace the sensor and supercharger?
Old Jul 31, 2024 | 09:24 AM
BucsDude's Avatar
Default What,was the final cost to fix?
I've got same code but haven't yet investigated. What was the final cost to repair?
-Supercharger seals
miwachiru123
Mar 7, 2016 01:13 PM
PieceKeeper
Aug 14, 2013 06:48 AM
seanq73
Sep 27, 2011 05:20 PM
al_ngl
Aug 27, 2011 07:25 PM
mainevolvo52
Apr 24, 2008 08:27 PM
