code BCM 0103 Brake pedal sensor
Old Sep 4, 2010 | 07:15 PM
rob40cal's Avatar
Default code BCM 0103 Brake pedal sensor
Also code ECM 9400.Any techs know if this code means the sensor needs to be replaced or is it some thing else. If so is the brake pedal sensor on the brake booster replacable.
Rob
Old Sep 4, 2010 | 07:19 PM
The brake pedal sensor commonly goes bad. It is the sensor in the front of the brake booster.
Old Sep 5, 2010 | 05:09 AM
rob40cal's Avatar
Thank you Tech for that info.
Rob
Old Sep 5, 2010 | 06:27 AM
Your welcome.
1996850turbo
Feb 12, 2014 12:14 AM
chef
Feb 16, 2009 08:27 PM
1996850turbo
Aug 26, 2008 08:35 AM
1999S80T6
Feb 15, 2008 05:50 PM
morningcalm
Dec 18, 2006 09:09 PM
