Connectors between right rear ABS-sensor and BCM?
Old Oct 15, 2022 | 04:36 PM
SirK's Avatar
Default Connectors between right rear ABS-sensor and BCM?
Got a 2004, XC90 2.5T with an electrical issue..
Got code 0041 Right rear wheel sensor. Faulty signal.
Changed both ABS-sensor and wheel hub, including the magnetic sensor. But still got the same code.
It might be the BCM, but I would like to check the connectors between the sensor and the BCM first, but where are they located? How do they look like?
Old Oct 15, 2022 | 07:28 PM
Your first step would be to check the abs sensor signal with a compatible scan tool. Much cheaper that buying parts that don't fix the car.
Old Nov 27, 2022 | 11:20 AM
SirK's Avatar
Case closed, the new ABS-sensor was broken!
GMJim
Volvo C30
Dec 28, 2017 08:05 PM
patricka
Nov 24, 2012 06:33 PM
sjbyy520
Jul 24, 2011 06:48 PM
537playing
Sep 7, 2010 06:15 AM
Vincent12773
Mar 25, 2010 03:44 PM
