Driver seat removal
Old Jul 12, 2016 | 10:17 PM
Paulpk's Avatar
Default Driver seat removal
I need to remove my drivers seat to repair it. Will disconnecting the battery cable protect me from the airbag inflating?
2003 XC90 T6 AWD
Old Jul 13, 2016 | 06:18 PM
comancheflyer's Avatar
Removing the front seat
Remove the battery lead. See .
Remove:
■ the four side pieces over the screws for the seat. Pull the front side pieces straight forward and the rear side pieces backwards and upwards to detach them
■ four screws.
■ the side panel. See
■ the seat belt from the seat
■ the connector.
Disconnect any remaining connectors.
Remove the seat.
To prevent electric static discharge problems:
When removing a seat with a SIPS (side impact protection system) module from a car, the seat must be grounded. This is due to the danger of static electricity.
Detach the chair from its screwed joint. Do *not* lift the seat out of the car yet.
Strip a long cable at both ends. Secure one end to the rear mounting on the chair. Secure the other end in the car or in the car hoist.
Old Jul 13, 2016 | 06:44 PM
Paulpk's Avatar
Got it, thanks for the quick reply
Old Jul 13, 2016 | 10:07 PM
ES6T's Avatar
Or just take the key out. You'll be fine
Old Jul 14, 2016 | 11:29 AM
Paulpk's Avatar
You're saying no need to disconnect the battery? Just make sure key not in ignition.
Old Jul 14, 2016 | 01:50 PM
ES6T's Avatar
Yep, that's how we do it. You can disconnect the battery if you want, it doesn't take long.
Just don't turn the key on at any time when the seat is disconnected or else you'll need to have the SRS light reset.
Old Jul 15, 2016 | 06:23 AM
Paulpk's Avatar
Ok, thanks
RobJamesInSheffield
2001-2013 model year V70
Apr 26, 2015 03:03 PM
Sir Vivor
May 8, 2013 02:29 PM
redheadskier
Feb 1, 2010 11:55 AM
fjkai
Jul 2, 2009 07:37 PM
Olivia
Feb 12, 2007 08:48 PM
