Driver's Power Seatback "Shifts" on Occasion
Old Aug 15, 2007 | 02:08 PM
2_Ton_Baby_Box's Avatar
Default Driver's Power Seatback "Shifts" on Occasion
Hello all. I've been having this problem since the car was nearly new: The drivers power seat has been set with a memory to my preferred driving position. However, after a several exits/entries, I find I'm too far back and a tap on the memory key brings the seatback up at least a couple of inches. It seems to slowly recline as I enter and leave the seat. I've also felt an odd 'click' or 'pop' in my lumbar region which makes me think the seatback has moved, but it hasn't - and normally after I feel this and hit the memory key, the seat is already at the correct position (no adjustment needed). Any ideas or similar experiences? Thanks.
Old Aug 19, 2007 | 11:11 AM
raygu's Avatar
Default RE: Driver's Power Seatback "Shifts" on Occasion
Do you always use your own key? The second key may have another driver's preferred positions programmed which will cause the seat to re-position.
Old Sep 25, 2007 | 05:44 PM
eajbrian's Avatar
I have all three memory location s set to the same and it still shifted. Iask and they think when I exit, my "behind" bumps the seat back lever. I did not.
Brian
Old Oct 25, 2007 | 07:21 PM
Well, the problem was finally solved when the dealer replaced all the switches and sensors in the drivers seat. No more slipping out of position.
ijourneaux
Jan 12, 2014 11:13 PM
kartman01
Aug 19, 2006 10:09 AM
tomservo
Apr 14, 2006 09:37 PM
850forum
Nov 28, 2005 09:41 PM
