ENGINE OIL
hi
I had a quick question i want to change the oil on my volvo xc90 53k and i think the 5-30 is too thin and maybe going through the turbos causing oil sweating. How much heavier can i go since it is a turbo charged engine and the oil needs to be fairly thin. Also what are the best spark plugs i can put in there i know i cant put the bosh fusion because there is too much spark, should i just buy single prong? And lastly has anyone tried a K and N air filter?
THanks in advance
THanks in advance
If full synthetic, 5W-30 should be good in cold weather. Other than cold winters you may want to go with full synthetic 10W-30 or 10W-40. Let the engine idle for 1 minute before shutting it down after a freeway driving.
As to spark plugs, Genuine Volvos seem to be trouble free.
Not sure about K&N.
Make sure to follow scheduled maintenance.
JPN
Not sure about K&N.
JPN
I agree with JPN on the oil.
NGK is an excellent plug, Bocsh are crap. OEM cannot be bad.
K & N are over rated IMO. Do not get fished in on fuel savings being a plus factor.I have triedit on two other vehicles and was dissapointed. On the other hand if you are wanting performance there may be something there, but not much............
nuclearseal
Aug 17, 2022 01:48 PM
Nightc
Jun 1, 2015 12:51 AM
