Fault codes on 2004 XC90 2.9 T6
Old Apr 8, 2019 | 08:46 AM
Heidi Marie's Avatar
Default Fault codes on 2004 XC90 2.9 T6
My cars braking system hates wet weather, and these are the codes it throws up. Included in this post are pictures of the fault codes. I think it needs a new Brake pedal sensor and Rear Drivers ABS Sensor. Can anyone throw some light my way.
Thanks all in advance.
Old Apr 8, 2019 | 12:01 PM
sounds like it. Start with the RR wheel sensor - check to make sure the connector and wires have not been damaged. You should be able to remove and test/clean before replacing (check youtube for vids). Shouldn't be an expensive part ($30ish). The brake position sensors do fail from time to time. here's a handy vid to give you an idea of the how to
Old Apr 8, 2019 | 12:17 PM
I have purchased a new Brake pedal sensor as they are on discount (( better to save then spend more )) But will change the RR sensor first. If that resolves the problem I can always sell on the un-used Brake pedal sensor. I thought I had better double check on here I was heading in the right direction !! Thanks !
kase6000
Apr 21, 2015 04:36 PM
mojorysn
Feb 12, 2014 11:02 PM
ANDY BARNES
Oct 7, 2011 01:11 PM
chef
Feb 16, 2009 08:27 PM
1999S80T6
Feb 15, 2008 05:50 PM
