Front Windows coming up too high
I have had his issue once before: when closing the front windows, they would lift too high, and stay up, so i heard excessive road noise, and also windows lifting high would elevate the outside sheet metal and molding. It had happened in both auto-up and manual modes. The dealer made computer adjustment, and now in auto-up mode the windows go up right to the proper position. However, in manual mode (when you hold the switch in UP position) they first go up too high (lifting metal and molding on the outside of the door); and when you release the switch, they go down slightly to the "proper" position.
I just did 15000 service+tie rods recall, and the service advisor told me that only auto-up mode is ajustable, and manual mode IS NOT ajustable.
Anyone had/has similar problem?
And how did you solve it?
Thanks alot,
Yuri
Thanks alot,
Yuri
