Gas Pedal Adjustment for 2018 XC90
Old Jan 10, 2019 | 08:17 PM
Noahjb's Avatar
Default Gas Pedal Adjustment for 2018 XC90
Is there any way to adjust the height, spacing or resistance of the gas pedal on a 2018 XC90 T5 Momentum? My wife is short and even with the seat pushed in close, she has trouble comfortably reaching the gas pedal.
I know some cars have this as an option, but I don’t see anything in the manual. I noticed the pedal comes up from the floor as opposed to hanging down like the break pedal (and most other cars).
Does the R-Design come with a “sportier” pedal that I could buy and maybe solve this issue? Anything aftermarket?
Old Jan 12, 2019 | 11:41 AM
ES6T's Avatar
You would need to find someone to fabricate some sort of bracket that could attach where the pedal currently attaches and allows the pedal to bolt to the bracket in a closer position.
Old Jan 13, 2019 | 04:39 PM
Anthony Arzani's Avatar
Default Bracket
The bracket the pedal mounts to, is bolted down with three bolts under the carpet.
You can buy another bracket from the dealer and then mount it a little closer. You would have to remove the carpet and foam support to get to it.
jefhon
Jun 11, 2023 08:02 AM
JerrySC
Jan 3, 2020 03:22 PM
WhollyTerriers
Aug 14, 2018 11:45 AM
Teela
Jul 7, 2010 04:52 PM
Teela
Jun 30, 2010 04:16 PM
