HELP! At a loss, leaking like sieve
Recently I had a small oil leak coming from the front passenger side of the car, right under the motor mount. Now the leak is a lot, too much!
I thought it was the crankshaft/oil pump seal so I replaced that. Not that.
So then I thought it was the VVT hub seals, replaced those and the little or o-rings inside each hub. Not that either.
The majority of the leak seems to be coming from between the crankshaft/ harmonic balancer and the VVT hubs.
The only other thing I can think of is the turbo oil return line.
Any ideas?
Any ideas?
