turbo return seal oil leak s80 t6 '2000
Old Oct 9, 2011 | 04:48 PM
sparro's Avatar
Default turbo return seal oil leak s80 t6 '2000
Has anyone done this before?
I removed top cross bar. Then I removed the driver side heat shield. I tried reach my hand down to feel where the area was. I could not see anything.
How should approach my next step? Thanks.
Old Oct 9, 2011 | 06:44 PM
NoLifeTilBoost's Avatar
take a look from the underneath to get your bearings. Are you doing turbo #1, #2 or both?
Old Oct 9, 2011 | 07:16 PM
sparro's Avatar
I have oil leaks. Leak appears to be coming from turbo return seal on dirver side. From the bottom, I can see the passenger side oil return pipe, where leak is not that much. The driver side leak seems to be a few drops over night when parked. If I drive, the leak is worse. Some posts here say that the driver side leak (oil return pipe) can be reached from top.
I reached down with my hand below the driver side turbo charger but did not really feel oil. But I cannot see where else--unless oil leak from the passenger side travels to the driver side and drops.
Not sure how to get there..
Old Oct 10, 2011 | 06:10 PM
It may also be leaking at the orings where the pipes join the block. How does that area look. If you shine a flashlight up there and move around you should be able to see the drain pipes for both turbos if I remember correctly. Driver side one is a b1tch though.
Old Oct 11, 2011 | 01:27 AM
sparro's Avatar
Thanks. I will try to take a look again this weekend. I could not see the driver side turbo drain pipe.
pburchins
Aug 27, 2010 08:20 PM
redbottle
Nov 5, 2009 09:41 PM
dcarlson12
Oct 27, 2008 12:18 PM
v70 2.4t
Mar 1, 2006 02:21 AM
GaryBrad
Aug 12, 2005 12:48 AM
