Multiple Engine codes HELP!!!
Old Jan 10, 2018 | 07:13 PM
2.9turboturd's Avatar
Default Multiple Engine codes HELP!!!
Hey volvo family new to this site and was hoping to get a little help on my 2.9 turbo turd. I have (CEL) codes out the ying yang and need help solving them.
1st code:P0351
2nd code:P0353
3rd code:P0356
4th code:P0352
5th code:P0420
6th code:P0234
now I know the first 4 codes are miss fire codes but I just put new NGK platinums in and still no fix. Is it likely to lose four cool packs at once? And I assume the P0420 is for the catalytic converter? And not sure what the over boost is about as well? Any help would be great😞
Old Jan 10, 2018 | 08:30 PM
madman77's Avatar
1st code:P0351
2nd code:P0353
3rd code:P0356
4th code:P0352
5th code:P0420
6th code:P0234
Your "Over Boost" may be the cause of the other codes, causing a lean condition misfire and maybe over heating the "CAT".
You may have a vacuum leak going to the "wastgate" and it's not dumping some of boost.
Here's a video of how to troubleshoot..
Old Jan 11, 2018 | 11:04 AM
So I should start with the over boost code first?
Old Jan 11, 2018 | 08:13 PM
madman77's Avatar
Short answer yes, don't go throwing parts at it. Find the reason for the overboost that may have caused the other codes. You may get away with a 2$ vacuum hose like in the video.
Old Jan 11, 2018 | 08:41 PM
+1 on MM's advise. Start with the vacuum lines as that can cause lean trim issues and issues with the connected actuator. Also spray around for possible cracks in intake tubing - its possible overboosting blew a hole or cracked an intake air path component.
Old Jan 11, 2018 | 09:50 PM
Awsome thanks a lot guys I'll give that a try and see what I come up with
Old Jan 14, 2018 | 11:33 AM
Adam Critchlow's Avatar
First thing - don't panic. Trust these guys in the forum, they know what they are doing.
Things to Check:
Vacuum Lines (google how to find vacuum leaks) - it's likely that this is the culprit of MOST of the problems you are having (if not all). I would check/replace the PCV lines, unless you've done so recently thats worth doing - even if it isn't the "problem" here.
Get an OBDII reader - they are cheap, and will give you more information. I like the BlueTooth type, so it pairs with the phone and you can actually see a little more information. OR get a Vida/Dice setup(or whatever the current/corrent version is called now) that will give you A LOT of data to look at.
I just had a similar problem with my XC90 - T6 (P0420 code) you can see the progress here 2004 xc90 t6 - p0420 (don't know if posting ext. links is acceptable on this forum... but it's worth a shot)
Adam
Old Jan 14, 2018 | 11:55 AM
Im dumb, clearly you have some sort of OBDII reader. Carry on.
Xtossin
Apr 1, 2021 02:56 AM
Galaxy850Sunny
May 7, 2014 03:45 PM
wieder
Sep 10, 2010 08:42 PM
keimini
Oct 14, 2009 11:52 PM
keimini
Oct 12, 2009 11:22 PM
