Multiple messages on dash
Old Aug 2, 2012 | 04:22 PM
Saxongwara's Avatar
Default Multiple messages on dash
ok, this all started about a month ago when I returned home from vacation. The first message read "ENGINE SYSTEM SERVICE URGENT" with a red triangle in the dash. The next day the message was gone. Then it returned a couple days later. Then disappeared again. That happened for about a week and hasn't returned (yet). The second message was "ALARM SYSTEM SERVICE REQUIRED" with the yellow info light. The same thing happened with this message (it was on one day, then gone the next). Next message is "BULB FAILURE LOW BEAM" and my right low beam bulb is out. I'm going to swap the bulb with the left one tonight to make sure it is in fact the bulb. The 4th and final message just happened today. "POWER STEERING SYSTEM SERVICE REQUIRED". This message only appeared for a second and then went out. Please help. Thank you all
Old Feb 26, 2020 | 02:03 PM
kaysrai's Avatar
Default How was it fixed?
Could you please advise how it was fixed? I'm getting same errors. Thanks.
Old Feb 26, 2020 | 02:39 PM
for random error codes that appear/clear, start by testing for alternator/battery voltage issues. Behind these dash messages are OBD2 codes - so also have the car scanned for the individual stored fault codes. Finally, it really helps if you post the model/year of your car...
Old Feb 26, 2020 | 04:32 PM
kaysrai's Avatar
2009 XC90 with 3.2 motor
Old Feb 27, 2020 | 08:02 AM
moved thread to XC90 forum
trek8288
Oct 8, 2023 09:54 AM
majorcode
Nov 10, 2014 06:41 AM
v70 2.4t
Jul 5, 2007 10:46 PM
nwekwerth
Feb 26, 2005 01:15 AM
