Power assisted brakes
Old Sep 14, 2016 | 12:54 PM
miked3324@gmail.com's Avatar
Default Power assisted brakes
I have a question.
I recently had my engine replaced and b4 i did my brakes were perfect.
After the engine was replaced I no longer have power assisted brakes
I can pump brakes and get assist but only for that 1 stop. If i apply brakes again.. No assist.
I replaced vacuum pump and checked check valve and switch all working fine.
Why am I not getting power assist when braking unless I pump brakes
Its a 2005 volvo xc90 t6
Please help!!!!
Old Sep 22, 2016 | 02:23 PM
firebirdparts's Avatar
What does it feel like to have no power assist? High pedal or low?
Old Sep 22, 2016 | 02:32 PM
Low peddle
Unless u pump them then its nice high peddle
Doesnt feel like you have to force the car to a stop with the power assist
Without pumping brakes.. Feels like you have to force the car to a stop everytime.
Any ideas????
Old Sep 22, 2016 | 02:33 PM
Low peddle
Unless u pump them then its nice high pedal
Any ideas????
Old Sep 22, 2016 | 08:41 PM
Your problem is air in the lines. No biggie. Just need to be bled. I figured that was what it was.
Old Sep 22, 2016 | 09:01 PM
I thought it was air too..paid for the entire brake system yo be bleed ... They said they bleed it 4x and there is 100% no air left in the system.
Brakes got 10% better. But still no boost.
So whats the next guess??
Old Sep 22, 2016 | 09:32 PM
ES6T's Avatar
I would replace the master cylinder. But its hard to diagnose without driving to feel it.
Old Sep 22, 2016 | 09:36 PM
Already checked the master cylinder..its not leaking and all the seals are good.. Booster is also good.
Not sure what else it could be
Thats why I am lost.
Old Sep 22, 2016 | 10:31 PM
ES6T's Avatar
How did you check the master cylinder? Also make sure there isn't a big vacuum leak somewhere. Like the plastic pipes going to the turbos. Specifically near the upper engine mount if it has an air baffle on the pipe.
Old Sep 22, 2016 | 10:58 PM
the master cylinder was pressure checked and the seals checked no leaks and holds pressure.
The issue is volvo replaced my engine and b4 they did EVERYTHING worked 100% afterwords no brake boost assist. Yes brakes are new completely bleed and brake check replaced check valves new.. Booster and master cylinder had seals checked and been pressure tested. And vacuum pump replaced. Just trying to see what it is I missed. ?????
Old Sep 22, 2016 | 11:07 PM
It was taken to Meineke and they tested it
Old Sep 22, 2016 | 11:11 PM
ES6T's Avatar
Sorry, but not who I would trust. If there isn't a big vacuum leak, I'd put my money on the master. But again, hard to say without driving it and inspecting it myself.
Old Sep 22, 2016 | 11:18 PM
I'm in kansas.. Come see what u think
Old Sep 23, 2016 | 05:06 AM
ES6T's Avatar
No thanks
T K
Mar 22, 2011 03:32 PM
mark_disfree
Dec 19, 2008 01:10 AM
elderzap
Nov 7, 2007 04:58 PM
m_schiff83
Aug 10, 2007 05:06 PM
