random misfires at start up
2007 XC90 random misfires at start up. mostly cylinder 6.. compression is good. I changed plugs, I changed coils. I changed pcv diaphragm I changed intake manifold gasket I blew smoke to look for vacuum leak. I swapped the cam sensors ..I cleaned the mass air flow sensor I changed the fuel rail sensor WHAT THE FREAK PLEASE HELP I am lost.. added info i am having bank 1 sensor 2 post cat sensor issues at times..working just weird readout..HELP PLEASE.
I pulled the fuel rail. Checked the spray pattern on the injectors. It looked fine. No visible leaks what is your thought process on the coolant?
charlesmkern
07-22-2014 04:30 PM
