Rear O2 sensor location 2016 XC90
Old Feb 7, 2021 | 08:39 AM
vzz's Avatar
vzz
Default Rear O2 sensor location 2016 XC90
Hi,
Looks like I need to replace it according to the OBD2 scanner. Searching on internet I don't find a video/picture on where it is located. Anyone has experieces with this?
Someone mentioned removing a protective plate (for an earlier model). Is that the large underbody plate for splash/rust protetection or just small piece specifically for the the sensor?
A picture/video link is really appreciated.
Thanks.
Jeffrey
Old Feb 11, 2021 | 09:27 PM
jacek_canada's Avatar
Default Sensor
I posted very detailed thread about this . With pictures. Search this forum before asking.
Old Feb 12, 2021 | 08:08 AM
vzz's Avatar
vzz
Hi Jacek,
Thanks for your pointer. I did search but I missed it.
In addition, you mentioned that your "upstream" sensor was busted. Is that the front or rear sensor?
In your picture it does show a rear sensor, so that does help. A picture of wide angle would help even more for my situation so that I could see the surroundings :-)
Is that behind a protective plate? I read it as such in a post for an older model but I am not sure if that plate is a large underbody plate or a smaller plate specifically for the o2 sensor. I am new to this, and wanted get some advices before I start taking apart things.
The codes I got are: P0171, P2270, P0140. The latter two point to the O2 sensor. It seems that P0171 may be related to the latter two or simply for other reasons. Should I try replacing the o2 sensor or just ask the dealer to do more diagnosis to confirm the real cause first? With the P2270/P0140, it seems to be worth a shot to try replacing the sensor?
Thanks.
Jeffrey
Old Jun 14, 2021 | 02:49 PM
JAMESH's Avatar
The diagram is incorrect, the front is on the right and the rear is on the the left.
Old Jun 23, 2022 | 03:16 PM
zagato8182's Avatar
Jamesh ,
Do you have any pictures for the 2016 VOLVO XC90 momentum Bank 1 Sensor 2 replacement?
All I see is pictures of trucks.
jacek_canada
Jun 24, 2022 07:02 AM
no1billsfn@hotmail.com
Aug 26, 2021 05:37 PM
shepcontracting
Oct 5, 2018 11:36 AM
wespetersen@gmail.com
Jun 10, 2016 09:15 AM
Sensation!
Oct 13, 2015 08:21 PM
