Reduced engine performance and error codes
You need to take the car to a mechanic. After you look at the first page and see that fully 25% of the threads are from you. And after you see that 80% of your threads are about problems. And after you see that what you try to fix usually ends up more broken.
Seriously? Very loud fan noise, 11mpg fuel economy, error codes and no throttle response... and you're asking an EXTREMELY sparsely populated forum for help? You need to take the car to a mechanic, because each of those issues can result in major $$$. Especially 11mpg in your best-case mileage, which is so laughably bad, there's something seriously wrong with your car.
loud fan- fan needed to be re-calibrated 11mpg fuel economy nothing new its just becasue of the way i drive only problem is the throttle response which is getting fixed and its a throttle position sensor. the mpg's isnt even a problem ive gotten around 11.6 ever since i bought the car brand new there aint nothing wrong with it its just what i get. And dont tell me **** i already know fan boy ik more bout cars than you ever will i just use the fourms as a resource to narrow down potential problems
Agos
Sep 8, 2008 05:22 PM
