Steering Angle Sensor Issue.
Old Aug 8, 2017 | 01:25 AM
tubbs76's Avatar
Default Steering Angle Sensor Issue.
Hi all,
The dreaded Anti Skid Service Required error. Took it to a place to get scanned, came up as an angle sensor issue. Thought plausible as all the engine mounts are shot, no doubt alignment is out, etc.
Just got all of the mounts done and a front wheel alignment as a result. Ordered a new sensor and fitted it, pretty straight forwarded as it comes locked and is set to 0 degrees.
Took it this arvo to get scanned, re calibrated and error wiped and it wouldn't work. Now telling me I have code UO42864 - Invalid Data Received from Steering Angle Sensor Module plausibility failure. Any idea what this means and how to fix it? all help appreciated.
Old Oct 16, 2017 | 05:52 PM
ikeever's Avatar
same issue... I'm trying to find solution. Did you get yours figured out?
Old Oct 18, 2017 | 10:13 AM
ikeever's Avatar
Did you count the turns to make sure it was ~2-5-3.0 turns. I've heard stories about then not being centered out of the box.
jamesjc
Nov 29, 2019 06:09 AM
jamesjc
Nov 3, 2014 03:11 AM
winstonsmith
Mar 12, 2014 09:04 AM
robot808
Nov 7, 2013 07:13 AM
robot808
Aug 15, 2013 10:52 PM
