steering column adjustment lever
I just searched the forums and found that in order to replace the cheep molded plastic steering wheel adjustment lever on my '05 XC90 I must practically remove the steering column. SERIOUSLY???!!! Could someone who has done this job please affirm what I found. I will spare you all the obvious rant.
98 S70 Broken Steering Wheel Lever
Did you ever find a way to fix this without removing steering wheel column?
Steering column lever broke
This literally happened to me today in my 2001 V70. I'm pissed cause i just finished replacing my cam seals and crankshaft seal. Which took me longer than i thought due to finances and my PTSD from the military. But with the steering column free and not locked I'm gonna assume it's not safe for me to do a test drive around the block.
Yes to replace the handle it looks like you have to remove 4 screw to lower the column to get enough clearance.
https://cimg4.ibsrv.net/gimg/volvofo...8677915194.jpg https://cimg5.ibsrv.net/gimg/volvofo...84ee0ded46.jpg |
