Steering issue
Old Mar 4, 2007 | 09:32 PM
XC90AWD's Avatar
Default Steering issue
My XC90 steering is sloppy and cannot control at higher speeds. It tends to steer by itself and needs constant adjustment to keep it straight. I have replaced the control arm ball joint and tie-rods but the sloppyness is still there. Is it that my steering rack or the u-joint might be causing this?
Old Mar 4, 2007 | 09:37 PM
Default RE: Steering issue
You replaced both sides?
Old Mar 4, 2007 | 09:56 PM
XC90AWD's Avatar
Yes, I've replaced both sides of the control amr ball joints and inner & outer tie-rods as well as the right control arm bushing as there was a tear.
Old Mar 4, 2007 | 10:09 PM
Maybe slack in the rack.
But I know they are a little loose when driving on the highway.
So all the control are bushings are new?
Does it pull hard to one side when accelerating?
Old Mar 5, 2007 | 01:54 AM
XC90AWD's Avatar
Yes steering feels loose and hard to control. It tends to pull to the left most of the time.
Old Mar 5, 2007 | 03:07 AM
XC90AWD's Avatar
How do I remedy a slacked rack?
Old Mar 5, 2007 | 08:40 PM
If it was the rack then you would have to replace it.
But I would go over every bushing and part in the front suspension.
We had one that had a bad control arm bushing it pulled really hard to one side under acceleration then went straight when the gas was let off.
replaced both control arms all was fine.
Old Mar 6, 2007 | 12:09 AM
98v70's Avatar
I am commenting on this issue because I'm actually looking into a 04 xc90 and found out that there's an open recall on the ball joints. This may be related? XC90, were they replaced by the dealer via the recall?
Old Mar 6, 2007 | 12:56 AM
XC90AWD's Avatar
yes, the outer tie rods were replaced under recall. I have visually checked the bushings in the front suspensions and looks to be OK. The camber have been adjusted but it still tend to steer to the left.
Old Mar 6, 2007 | 12:59 AM
XC90AWD's Avatar
Yesterday went to workshop and adjusted the rack, feels better now but the pull to the left still there
Old Mar 6, 2007 | 04:46 AM
98v70's Avatar
you might just want to try an alignment. what year do you have?
Old Mar 6, 2007 | 09:48 AM
XC90AWD's Avatar
it's a model year 2004
Old Mar 6, 2007 | 08:40 PM
Never knew the rack was adjustable.
Do you have new tires on it?
Old Mar 6, 2007 | 10:06 PM
XC90AWD's Avatar
Tightened the nut located below the rack where the rack and steering column connect. I had my tyres changed about 9 months ago.
Old Mar 6, 2007 | 10:10 PM
XC90AWD's Avatar
Is it possible one of the front shock absorber is bent?
Old Mar 6, 2007 | 10:13 PM
Possible but doubt it.
If you can try rotating the tires and see if the pull goes away.
Or just swap the 2 front tires.
Old Mar 6, 2007 | 10:17 PM
  #17
XC90AWD's Avatar
I had my tyres rotated back in november last year, and feels the same
Old Mar 6, 2007 | 10:24 PM
  #18
Try criss crossing the fronts.
Old Mar 6, 2007 | 10:27 PM
  #19
XC90AWD's Avatar
You mean, the right front wheel to the rear left wheel?
Old Mar 8, 2007 | 08:27 PM
  #20
No swap R/F and L/F
