timing belt change and VVT
Hello!:)
im changing my timing belt of my xc90 t6 (2.9L dohc ) and i just realized that booth of the camshaft sprockets with a "center can" wich i think they are the VVT mechanism they are loose, this means that if i turn any of the sprocket to left or right they will not return to the original position. anyone that has done it before on a T6 o knows something about it, is this normal? or those "cans" are damaged?:confused: i will appreciate any input. Thanks Guys!! |
That is normal make sure the marks are lined up with the top cover and you will be fine.
