whine in front end under acceleration only
Old Mar 2, 2018 | 02:35 PM
ylwgto's Avatar
Default whine in front end under acceleration only
Hi,
My 180,000 mile '04 XC90 2.5T AWD has a significantly noisy whine in the front end. Seems to originate around the driver footwell. It becomes audible from about 40mph to about 80mph, above which it seems to cease. This only manifests under acceleration and the pitch becomes higher as a function of increased speed, NOT RPM. Noise immediately goes away on deceleration. No issues with engine or transmission (that I know of) and it runs fine otherwise.
Can I rule out wheel bearing noise since it stops when I take my foot off the gas?
Can I rule out transmission b/c it's not linked to RPM?
Could it be a transfer case or differential issue?
CV joint noise (no cracked boots)?
It's loud and annoying, so any ideas?
Thanks!
Old Mar 3, 2018 | 07:20 AM
tony1963's Avatar
It sounds like the drive gears in the transfer case. It is not the end of the world, but the gears are not sold separately.
Have it checked on a lift with a mechanic's stethoscope and source a good used part.
stevepaa
2001-2013 model year XC70
Mar 26, 2016 01:47 PM
clintjay1977
Apr 21, 2012 11:48 AM
RUSSELL72
Oct 10, 2011 09:54 PM
andrewjc4010
Mar 22, 2011 08:02 AM
NJGreenBudd
Jan 11, 2009 09:00 PM
