XC90 2013 Air Conditioner Blows Hot
Old Aug 9, 2022 | 10:44 AM
  #21
That method of charging will work (somewhat) and was common when systems were charged with r12 freon years ago. You add until the low side pressure is what YOU thought is ok. And you can still do that with r134 with varying results.
Refrigerant is put in by weight. Approx 1 kg. (specs are usually written under the hood) for a full charge. With r134 too much or too little does the same thing - poor or no cooling. R12 was not as picky and would still work ok under or over charged. That silver can in the yellow (low side) line is used to inject dye or oil into the low side.
Old Aug 9, 2022 | 10:56 AM
  #22
charsiufan's Avatar
A lot to learn here! I believe the mechanic did it by looking at the pressure. It was ice cold once he finished but a week or so later can’t say that’s still the case although it is cold.
adamvolvodenver
Jun 10, 2022 11:16 AM
brickworks
May 20, 2022 02:00 AM
Ril
Jul 19, 2020 02:10 PM
golow
Apr 14, 2019 08:44 AM
JimR
Aug 23, 2012 10:59 AM
