Xc90 fuel leak, help!
2008 xc90 3.2p
I have a fuel leak, from the fuel pump, to the front of the car. It seems it's the hose I disconnected in picture, and it feeds to through the tank and I believe is attached to this big hose in the picture below. Runs to front of thr car.. The leak is about 6" from that connection off the fuel pump on that hose. I was going to just cut the big hose, run a string around it and pull it through reverse the procedure with new hose attached. But I feel like it's not directly connected and it is T off under there. I can't seem to find any diagrams of this to figure out what's going on and I need to fix it before I drive the car. Any help or suggestions or diagrams, i can't find anything. Thanks. https://cimg0.ibsrv.net/gimg/volvofo...9f901d60c1.jpg https://cimg2.ibsrv.net/gimg/volvofo...15c70691e3.jpg |
Originally Posted by Vossj08
(Post 525240)
2008 xc90 3.2p
I have a fuel leak, from the fuel pump, to the front of the car. It seems it's the hose I disconnected in picture, and it feeds to through the tank and I believe is attached to this big hose in the picture below. Runs to front of thr car.. The leak is about 6" from that connection off the fuel pump on that hose. I was going to just cut the big hose, https://cimg2.ibsrv.net/gimg/volvofo...7902752cf5.jpg https://cimg4.ibsrv.net/gimg/volvofo...ce8f4d81fd.jpg |
Thanks. Now to figure out were the second connection is. I'd assume they wouldn't bury the connect and make it accessible somewhere??
It's driving me nuts I just want to fix this leaking fuel hose. |
Well I figured it out. Goes to the fuel filter. But disconnected I don't get any slack in any of the lines.
