Xc90 fuel leak, help!
Old Jul 4, 2023 | 10:58 AM
Vossj08's Avatar
Default Xc90 fuel leak, help!
2008 xc90 3.2p
I have a fuel leak, from the fuel pump, to the front of the car. It seems it's the hose I disconnected in picture, and it feeds to through the tank and I believe is attached to this big hose in the picture below. Runs to front of thr car..
The leak is about 6" from that connection off the fuel pump on that hose.
I was going to just cut the big hose, run a string around it and pull it through reverse the procedure with new hose attached. But I feel like it's not directly connected and it is T off under there. I can't seem to find any diagrams of this to figure out what's going on and I need to fix it before I drive the car.
Any help or suggestions or diagrams, i can't find anything. Thanks.
Old Jul 4, 2023 | 03:08 PM
Originally Posted by Vossj08
2008 xc90 3.2p
Looks like there is a t fitting in that hose - can't tell you where the 3rd connection point is.
Old Jul 5, 2023 | 04:22 PM
Vossj08's Avatar
Thanks. Now to figure out were the second connection is. I'd assume they wouldn't bury the connect and make it accessible somewhere??
It's driving me nuts I just want to fix this leaking fuel hose.
Old Jul 5, 2023 | 04:57 PM
Vossj08's Avatar
Well I figured it out. Goes to the fuel filter. But disconnected I don't get any slack in any of the lines.
godfearer960
Apr 30, 2023 11:21 PM
hmmmmm
Feb 20, 2018 07:39 PM
katman104
Feb 9, 2018 03:09 PM
Carl W French
May 31, 2013 11:16 PM
just45
May 4, 2011 10:51 AM
