XC90 Serious Coolant Leak
Old Oct 25, 2022 | 04:50 PM
Greshams's Avatar
Default XC90 Serious Coolant Leak
I have a 2004 XC90, 2.5 turbo, AWD. I was driving the car in my neighborhood and a neighbor stopped me to tell me that liquid is leaking from the engine compartment. I drove home, parked the car, turned off the engine, stood about 3 feet from the front of the car and saw a steady stream of coolant leaking near mid-car/passenger side near the bottom of the radiator.
I placed a bucket under the leaking area. I refilled the coolant reservoir and within 15-20 seconds, the leak appeared again in the same location. I refilled the reservoir a second time and got the same result.
I refilled the coolant reservoir again and started the engine. The leak was slower, but was still present. Could this be a busted coolant hose or hole in the radiator? This is first time the car has had this issue.
Thank you!
Old Oct 25, 2022 | 04:55 PM
Yes, do not drive the car any further - a damaged head gasket will cost $$$$$
Simply rent/borrow a radiator pressure tester and locate the leak - then solve it.
Or have the car towed to your trusted service provider.
Old Nov 2, 2022 | 04:04 PM
Greshams's Avatar
Thanks, hoonk! I took the car to my trusty mechanic. He tested the radiator's pressure and found 2 areas where the plastic radiator was cracked. The replacement cost was $525 total. I can't complain because the car is 18 years old with over 231k miles and it's been pretty reliable.
Old Dec 5, 2022 | 12:57 PM
Taskism's Avatar
Daaang bro. Ive had a radiator leak for 2 years and i just been topping it off every day. I did not consider this head gasket nonsense. This makes me concerned
Old Dec 5, 2022 | 01:41 PM
If your car drips coolant or you can see residue on parts (like along the side seams of the radiator) you have a leak and should fix the problem area before the small problem becomes a big problem... The point was about not driving a car that's just dumped coolant as a simple overheat on a car with an aluminum head can warp the head causing a head gasket leak. Best to get a tow than chance limping home and turning a $500 repair into a $3500 repair.
grantxu2000
Feb 3, 2016 07:47 PM
jaynmaria
1998-2000 model year V70
Aug 22, 2012 06:09 PM
osbain
Jun 1, 2012 06:01 PM
pforsyth
Oct 25, 2010 09:02 PM
Megatron
Jan 31, 2010 01:19 AM
