XC90 T5 Engine Trouble Help!!!! P0300 (P0302 & P0305)
hello Everyone,
i am starting a new thread to try and sort out my engine troubles once and for all
ill try and be a brief as possible as i need opinions as to what this could be
youtube videos: -
https://www.youtube.com/watch?v=phl-...ature=youtu.be
https://www.youtube.com/watch?v=wp7G...ature=youtu.be
symptoms :-
Engine Light flashing prior to turning over
Engine light - P0300 (P0302 & P0305) Intermittent Misfire
Ignition Advance on Cold Mornings (Ignition Advance is Intermittent Depending on ambient temaparture)
Audiable Engine Stutter (Misfire can also be herd from exhaust)
Temprature on dash does not seem accurate e.g outside temp -10c it will tell me its 0c so seems to be 8-10 degrees off
large oil leak that appears to be coming from the cold air charge pipe both
ends apper wet (Throttle Body Connection and Rad Connection) oil seems to be leaking from the Rad end
pipe to PCV appears to be moist
dip stick has oil shot up the back
screeching noise from AUX belt / Timing belt area
so far i have replaced:-
Compresion Check Has Been Done
Coils with IPD ones
spark plugs with the official Volvo / Bosch ones
Fuel rail, Injectors and Fuel Filter
oil serveral times
Catalyst
3 bottles of Seafoam
and Brand New Battery heavy duty
please help me its starting to do my head in !!!!
thanks
Chris
youtube videos: -
symptoms :-
Coils with IPD ones
oil serveral times
Catalyst
thanks
Chris
christopherandrews1989
Feb 20, 2014 12:53 PM
Dano
Jan 6, 2010 08:28 PM
