Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
1991 Volvo 940SE tires and wheels woes - words of warning
Old Oct 5, 2018 | 09:51 AM
Elmwoodie's Avatar
Default 1991 Volvo 940SE tires and wheels woes - words of warning
My 1991 Volvo 940SE came with : P205/60R15 on what looks like original finned Volvo aluminum rims.
According to Volvo Bolt Pattern Guide Database RimHelp.com The car has the following
OE wheel size: 15"x6" and Bolt pattern: 5x108 Stud size: 12x1.5b Hub center bore: 65.1 Offset: M
I bought a set of winter 195/65R15 on steel rims with correct bolt pattern from a 97 Volvo 850.
Tires install fine, but appear to be right up against brake shoes on front and wont rotate. On the back, the tires are occassionally rubbing on something.
I am now wondering if some wheels from a Volvo 740 (unknown year) SIZE 205 / 70 R15 bolt pattern 5x108mm center bore 65.1 mm are going to give me the same problem or not. Current for sale at: https://www.kijiji.ca/v-view-details...dId=1385744111
I am thinking of taking the jack and wrench over to the seller's driveway to install right there to verify fit.
Or am I going to have to make an investment in some passenger tire changeover to get some good rubber on the right rims?
Shawn.
Old Oct 5, 2018 | 10:50 AM
The 850s have an offset of about 40mm, the RWD Volvos about 25mm - The offet is the "ET" stamping on the rim that states the distance from the center of the wheel hub to the center of the rim - so if you put rims from an 850 onto a 940, the inside of the rim will be 15 mm (2/3inch) closer to the strut etc.
Wheel-size.com is a good resource for the specifics by model.
Old Oct 5, 2018 | 12:26 PM
Elmwoodie's Avatar
Thanks for the education mt6127!
Wheels that fit my car (1991 940SE) are : 6Jx15x25
The ones from the 97 850 that don't fit are: 6.5Jx15x43
For $100, I have learned less for more! LOL
So that should mean that wheels from the 740 (RWD right?) might be a fit!
According to Wheel-size.com, The 740 has a pretty wide variety of wheels and ET sizes though!
Do I need EXACTLY 6Jx15x25?
Will I basically have to try them to see?
Shawn.
Old Oct 5, 2018 | 09:35 PM
Doesn't need to be exact. If you find some ET20s or 6.5 or 7 inch rims with the cooectc bolt pattern and center bore, you will be fine
Marty Tanner
Jul 8, 2018 08:45 PM
jameswblacker
Oct 3, 2017 07:52 PM
Luke Woessner
Dec 9, 2016 12:47 PM
thesam1984
Dec 21, 2015 10:20 PM
mikkowus
1998-2000 model year V70
May 15, 2015 12:41 PM
