Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
2002 s60 has bent rims any good ideas for custom wheels?
Old 01-03-2018, 05:53 PM
turbotim23's Avatar
Default 2002 s60 has bent rims any good ideas for custom wheels?
Hi bought a 02 volvo s60 that was in a car wreck.It has bent alum. front rims. I've looked for used rims,not much luck here locally. I also checked into getting these rims straightened, cost was very high. If I spend that much I would much rather buy custom rims. I looked online but all I find are 20" huge rims. Not what I want, I want to be able to use the 16" tires that are on the car now. Got any good suggestions? Are there any other cars with rims that will fit a s60? Thanks
Old 01-03-2018, 07:42 PM
most volvos share the same 5x108 bolt pattern and center bore with some minor differences in offset. If you want to buy replacement rims, there's several OEM replacement web sites. Check out hubcaphaven.com as an example. Also if you know your rim's part number or style name (or post a picture) you can google it to find OEM or replacements. Example try googling "Volvo 86331386" and you'll find you can score some 16 inch OEM style rims in the 125 to 150 range...
Old 01-04-2018, 05:47 PM
turbotim23's Avatar
Thanks for the reply. I checked into hubcaphaven.com for stock rims ,not too bad. prices are about what I found elsewhere, but I think they sell more stock wheel options. I might change the rims to one from a completely different model volvo than my s60. Change the look of the car a little or at least look into how much it would cost. Thanks again
Old 02-28-2018, 07:08 AM
tony1963's Avatar
eBay is full of used and reconditioned wheels. I've bought several Volvo wheels there myself with no issue.
Old 03-02-2018, 04:47 PM
turbotim23's Avatar
Thanks I ended up buying a good used rim and tire at lkq pick a part yard for 45.00. So you can find them just have to keep looking. The car had two good alum. rims with great tires but I could only get one rim off the junk car. There were also other different shaped volvo rims that would work as a spare even though I would not want them on the car normally. I might wait till they have their holiday sale and get one of those just for in the trunk. Thanks for all your help!
Old 04-09-2021, 05:10 AM
morguz38's Avatar
try Vorsteiner wheels, there are alot of cool designs, durable and not that expensive. i got mine in this site, here is a link for reference. https://unleashedwheels.com/collecti...steiner-wheels
Aiden Curry
07-24-2020 11:54 AM
AjRowan1
08-14-2015 08:05 PM
VolvoS60R
11-19-2010 11:16 AM
FoCelestial
06-18-2007 08:36 PM
Viraaj
11-08-2006 01:12 AM
Quick Reply: 2002 s60 has bent rims any good ideas for custom wheels?
