Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
235/50/17 will they fit? 08 s60
Old Oct 30, 2011 | 10:03 PM
laser99's Avatar
Default 235/50/17 will they fit? 08 s60
I have an 08 s60 2.5t fwd. I have an extra set of winter wheels and tires I'd like to put on. There 235/50/17 does anyone know if the will fir? any issues? it has factory suspension.
Old Oct 31, 2011 | 05:25 AM
jks2's Avatar
Generally the 17" tire size is a 225/45 size. This tire is slightly wider and taller. It will probably fit but you may experience some rubbing on full lock turns.
Old Oct 31, 2011 | 12:15 PM
laser99's Avatar
Sweet. Thanks for your help. What the ideal offset for 17x7 wheels? Any room to go + or - a few mm?
Old Oct 31, 2011 | 03:46 PM
jks2's Avatar
Offset should be somewhere around 43mm. Less than that and rubbing is a distinct possiblity, if you don't use spacers.
mcaanda
Mar 28, 2011 07:42 AM
eae
Feb 22, 2011 02:53 PM
Boondockindoo
Jan 7, 2011 01:11 PM
2004VolvoS60_Bilal
Sep 29, 2008 07:54 PM
ftremblay
Jun 7, 2005 01:59 AM
