Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
Tire size question for S60R
Old Sep 7, 2007 | 12:10 AM
AhDoi's Avatar
Default Tire size question for S60R
Anyone run 235/50/18 or 245/40/18 with any issues?
Old Sep 7, 2007 | 04:01 PM
TheSteelKnight's Avatar
Default RE: Tire size question for S60R
I have the18" rims on my S60 R. there is a little tire rub, but you can control that.
Old Sep 7, 2007 | 07:16 PM
AhDoi's Avatar
I have 18" rims too but what I'm asking is about tire size. 245/40/18 or 235/50/18. Is this ok on the R's?
Old Sep 7, 2007 | 10:06 PM
I would always go with what comes from the factory. you know it will work then which i believe are the 245/40/18's
Old Sep 8, 2007 | 03:05 AM
AhDoi's Avatar
Actually the factory specs are 235/40/18. It has been said that even with factory, there can be some rub when you turn your wheel all the way to one side.
The reason I'm even considering 245/40/18 or 235/50/18 is because someone is selling a used set of snow tires and I'd like to see if it'd be ok to use them.
Old Jun 12, 2013 | 04:54 PM
ExTuscani S60R's Avatar
Hello AhDoi. My S60R have four 245/45R18 Dunlop Direzza with no rub issues. It will rub only when you are in reverse and turn a lot the wheel.
Other than that not rub at all
diehardgator1
Feb 22, 2009 11:54 AM
HummerGuy
Oct 10, 2008 08:02 AM
dodwrx
Nov 1, 2007 10:56 PM
zmontgomery
Mar 3, 2007 03:15 AM
postdoc99
Feb 3, 2006 09:38 PM
