New to Volvo! But Excited
New to Volvo! But Excited! NEED YOUR GUYS THOUGHTS!
Hey Guys!!
I have some odd problems with my 1998 Volvo V70 XC AWD.
I have replaced my Rear Drive Shaft,
I have replaced the rear brake pads
I have replaced front struts and mounts
I have changed oil
I have changed the ABS Module
I need to do the rear trim (as usual for these vehicles)
The problem's are as follows.
1: All 4 brake rotors heat up, like so hot if I spit on them it sizzles and fry's. I dont know why because I only changed the rear pads so I dont know why I would have all four heating up..... yes all calibers are working and lubed and not seized.
2: There is a noise in the front end. Like I said I replaced the front strut mounts assuming they were bad, correct, however it did not take care of the sound like there is something loose in the front end. Sounds like it is coming from the wheel wells but I cant be sure. Sounds like there is a lose bolt that goes up and comes down and hits metal because it is not tight but I do not know where it is coming from.
3: Every other day or so there is the smell of burning oil for about 10 seconds. Seems like a slow drip from the rear of the engine compartment that hits the muffler and vaporizes leaving behind the smell but I am not sure. Anything common with this?
Mostly concerned with 1 AND 2...
Let me know your ideas!
Thanks guys I appreciate it.
I have changed oil
