2011 XC70 ignition coils
Old 02-08-2017, 12:51 PM
swissmiss's Avatar
Default 2011 XC70 ignition coils
We have a 2011 XC70 T6 (polestar). I've done a internet search and it shows checking them with some sort of spark tester one at a time out of the vehicle. Is there a good way to test the coil packs with a meter? If so, what are the normal resistance readings and pins?
Thanks in advance.
Old 02-08-2017, 03:25 PM
Smith Volvo's Avatar
Banned
You will get a check engine light and associated cylinder number if you have a misfire
Old 02-09-2017, 08:05 AM
swissmiss's Avatar
yes, and it ran a bit rough, turned around but we couldn't make it back home and coil shorted out and popped a fuse, and that was all she wrote. Got it towed and dealer fixed, but I want to check the other 5 coil packs to see if any of the other ones are iffy and hoping there might be a way to do it with a meter. I guess we'll just replace the other 5 so they'll all be new and spark plugs while we're at it. Have 90k miles on the car so I suppose it's time for it.
Old 02-12-2017, 01:08 PM
tony1963's Avatar
You can check the coil packs, but it will either test good or not. There is very little inbetween. Sort of like glass. It might be ready to break, but it isn't broken yet.
Instead of being worried about it, just replace them all. I have used aftermarket coil packs for nearly 20 years without issues. They are no better or worse that OEM.
Old 02-13-2017, 08:21 AM
swissmiss's Avatar
Okie dokie.....Thanks a bunch Tony
roytoronto
04-26-2009 10:59 AM
roytoronto
04-05-2009 09:04 AM
jag2010
05-14-2007 07:16 AM
Ham
01-16-2007 10:00 PM
AT Girl
08-12-2005 09:49 PM
Quick Reply: 2011 XC70 ignition coils
