Door chime comes on randomly
When I am driving down the road the door chime will start to go off and the courtesy light comes on. If I open the door and slam it stops. It used to only happen one time per morning commute but now it happens repeatedly. Could it be a fuse? I really want it to be something easy....
Please help!
Please help!
sounds like a switch is a bit sticky or worn. You didn't mention what model / year you have but look for a small button switch in the door jamb. That switch gets pressed when the door is closed and it sounds like its not getting fully pressed when you close the door. Also the problem may be a worn door pin, meaning the door may not be closing as tightly as it used to... but knowing your model would help.
admasters
10-02-2022 07:20 AM
WongWebb
01-11-2013 08:29 PM
