Possible new S60 buyer with Sirius Question
RE: Possible new S60 buyer with Sirius Question
There are a few ways to do this:
1- Buy the Sirius tuner from Volvo (Not that easy / most expeisive / Dealer install)
2- Use an aftermarket tuner for Alpine (I think) and use it like the Volvo OEM (Easier / cheaper / You install)
3- Use a Plug and Play unit like the Sportster 4 or S50 and hook it up through the changer port on the Volvo radio (Easier than #1 / Cheaper than #1 / You install)
4- Use a Plug and Play unit like the Sportster 4 or S50 and just use its built-in FM modulator to broadcast the music to any FM station (Easiest / Cheapest / Easy install)
If you need more information, check out www.siriusbackstage.com. There are a lot of people there who will be more than willing to help you out.
ORIGINAL: Dads850
Are you talking about an aftermarket Sirius tuner or an aftermarket replacement for the head unit?
It was my understanding that there are no adapters for the 2007 S60s that would allow this.
Not a great option in NY where most of the FM band is used. Sound quality suffers greatly compared to direct connect.
I don't think so?......I think the connection is the same but the unit is shaped differently...The Sirrus set up in the S60 has a cradel it sits in right?
Dads850 is on to something down there....If you bought an s-60 with a Sirrus setup but no Sirrus reciever you'd spend more money getting it hooked up the right way (i.e. at the dealer) than you would by just buying a S-60 without Sirrus setup, putting an aftermarket head unit in (doesn't matter which one. They all have an auxilery input of some kind now days...so long as you spend at least $250ish) and then purchasing the right adapter for the auxilery with a couple RCA ends and 6' extention with a head phone jack on the other. Then, you're not limited to just a Sirrus unit.....you can then plug anything in that uses head phones.
Cheaper and more versitile to go the aftermarket rought.....though i don't know how difficult it is to install an aftermarket head in a S-60.....
