need help wheels wont come off
Old 08-24-2010, 10:32 PM
turbo940v's Avatar
Default need help wheels wont come off
I have a 1991 volvo 940 turbo i removed all the lug nuts and wheels will not come off they are the oem rims. is there a button or something thanks
Old 08-25-2010, 06:20 AM
No, sometimes they just get stuck. Kinda like they rust on when moisture gets between the wheel and hub. Sit on the ground and kick one side of the tire, try not to knock it off the jack.
I stopped on the side of the highway one day to help a guy with a 325i and he had the same problem. The wheel did not want to come off. We had to beat that thing really hard. Also my 850 T-5R had the same problem with 3 of the 4 wheels.
It helps to have the tires rotated once a year or so, it reduces the chance of this happening.
NOTICE TO ALL NEW CAR OWNERS... CHECK TO MAKE SURE THE WHEELS ARE NOT STUCK ON. TAKE THE TIRES OFF ONE AT A TIME TO MAKE SURE THEY COME OFF.
Old 08-29-2010, 09:04 PM
as a mechanic, i can tell you this is extremely common on all vehicles. get a hefty brass mallet or a dead blow hammer and whack the backside of the wheel- like the lip on the backside of the wheel. don't hit it more than once or twice in the same spot, turn the wheel. then when its off, put anti-seize on the hub.
Old 08-31-2010, 11:32 PM
gdog's Avatar
Exactly! +1; i.e. it's hammer time! As far as anti-sieze, we used to use this stuff called copper-grease i think..?
Old 09-01-2010, 10:35 AM
Just had another thought. One could take all the lugs off and drive the car around until the wheel comes loose. Just a thought. LOL
Old 09-03-2010, 08:35 AM
turbo940v's Avatar
well we used impact wrench to break loose the lugs. Good thing i never got a flat tire i would be out there for hours.Now i just need to find some rims if anyone is selling any let me know lol.
Old 09-07-2010, 07:53 PM
wyobear's Avatar
Cool wheel won't come off
I have three suggestions:
1. Move to a dry climate where rust is not a problem.
2. Buy a 10 lb. hammer and carry it in the trunk.
3. List it on Craigslist...For Sale!
Just kidding on these. But I do like the idea of taking off the lugs and driving it 'till the wheels came off. It's best not to beat on the wheels or brake drums, so try prying the wheel off with a long pry bar.(BUT NOT WHEN IT's ON THE JACK) The best idea is rotate, rotate, rotate! Try shinning up the brake drum, and the back side of the wheel and using spray Teflon when you do get the wheel off. Most of all ...have fun!!
Fern Schmidt
2001-2013 model year V70
08-13-2013 06:43 PM
and240res
08-25-2012 01:06 PM
SuperS40
02-04-2009 01:02 AM
talon187
01-14-2009 08:04 AM
volvo4lifeson
03-05-2008 08:43 PM
Quick Reply: need help wheels wont come off
