Penta Discuss Volvo Penta Marine Machines Within.
Piston Problem Volvo Penta D6 310a
Old Jun 17, 2011 | 04:15 AM
  #21
teico's Avatar
Default D6 350 problems on 1 and 6 piston
[QUOTE=teico;276683]I've tested injectors and they were 100% Ok, due to Bosch. All relevant ingeneers and inspectors I've contacted said Volvo should give us a correct answer as probably they know what is going on here. Why pistons 1 and 6? Why no alert before or durring it happens? To me it happens just 3 hours after regular maintenance service at very raugh sea. We almost sank! I skupe really Like to prevent others and myself to happen again!/QUOTE]
Old Jun 17, 2011 | 04:32 AM
  #22
teico's Avatar
Default Piston problem D6 350 (1 and 6)
I have problems with pistons 1 and 6. Engine is 2006, and has 480 hours.To me it happens 3 hours after regular maintenance service. I've checked injectors at Bosch service (they said they are 100% OK) and made few colsuntings with renomate engineers and different Volvo services in Europe. They all expect Volvo should help and correct the cause of this problem. The only answer from Volvo was that engine is no longer under warranty! Does anybody get any answer or solution to this problem?
Old Nov 24, 2011 | 03:42 PM
  #23
bektasoglu's Avatar
Is it possible to share photos of engine from 4 side(front,rear,port and starboard) before dismount the engine? We may see something.
Old Jul 1, 2014 | 07:53 AM
  #24
Ronde's Avatar
Default Same problem
Hi,
It seems that i have now this same problem. Without any notice my starboard engine blew. The VP service will take the engine out next week and I will got more details after that.
I talked with the previous owner of the boat and back in 2007 the same motor had a total breakdown. He was not 100% shure and VP-service never told the exact reason for the breakdown. But they thought it was the injectors. But anyway they changed the block, head, injectors etc. The engine was tested in dyno and everything was ok. The engine has been maintained every year By VP. After this the engine has done little bit more then 230 hours. And now again....
The rebuilt was 39K€ and it lasted for 230 hours. I would rather not spend 40K€ for 230 hours....
So my question how did VP solve this. Did you have any more problems after you had it rebuilt? Did Volvo have any comments to this?
Read about engines in norway and VP blamed the Diesel for this. But what seems strange is that the port engine has never had a problem but this has happened 2 times to the starboard engine????
Old Jun 5, 2015 | 09:48 AM
  #25
John Leslie's Avatar
Are the D6-310 Volvo Penta diesel engine able to be re-sleeved? Or how are they rebuilt if there are piston problems? Walls scored badly.
Old Sep 3, 2018 | 05:53 AM
  #26
PARAGON's Avatar
It seems that Volvo's D4 or D6 problems with injectors will have started in Norway but ... in 2016 it also arrived in Portugal.
In 2016 a D6-370 with 600 hours, started having difficulty starting until he died completely. The Volvo representative concluded that of the 6 injectors there were 3 that were damaged. According to the opinion of Volvo's representative, only the 3 damaged nozzles were replaced and ... in August 2018, without any alarm or warning, at least one of the pistons was broken !!! All the maintenance provided in the Volvo maintenance manual has been carried out and I am waiting for a justification by Volvo for the occurrence of 2016 and what is now happening.
If anyone is aware of any liability already assumed by Volvo for these situations, I appreciate the collaboration.
Old May 25, 2019 | 06:29 PM
  #27
George Ioakeimidis's Avatar
i have a problem with my d6-ips600-435 hp ..probably piston is brake ..tomorrow we start to open and see what hapen't ..i will inform the forum .. the engine have 325 hours and after 30 seconds of start ,i give half of throtle and i heard a very bad noise .. after the power is down ,and alot of smoke come out from the evaporation..i keep in touch ..
Old Oct 17, 2019 | 08:04 PM
  #28
Rfelice's Avatar
Can you please let me know what the outcome was when the engine was opened? We are in the process of purchasing a 2008 Regal 4460. The oil sample came back with a aluminum reading of 140. Over 40 is considered severe. At this point they are saying that a rebuild is $25,000 and may negotiate the price. The boat is in excellent condition and did very well on the engine inspection and the survey. What worries me is that the same engine had been replaced by regal/Volvo while it was still under warranty. It had around 600 hours at the time and the replacement has about 500 hours. When aluminum is present it is usually due to pistons. I am concerned that there is a cause as to why this is happening again. Is there something that is causing the wear of the pistons that would not be fixed when the long block is replaced? Please forward nay advice that you have on this matter before the sale goes through. Thanks.
Old Oct 18, 2019 | 06:15 AM
  #29
Rfelice's Avatar
Originally Posted by max2000
Hi,
I have the same problem in Italy with one of the two D6 310 of my boat
They have less than 200 hours(!!) : I bought in july 2005.
We just tested the jniectors by an official Bosh technician and now we are sure that they are running good.
Therefore we must find an other cause
We are still investigating.....
Pls let me know if you have some...idea.
Thanks a lot in advance !!
max
Did you ever figure out what was going wrong with your engine? We are purchasing a boat and we found out that the one of the engines blew after about 500 hours. Regal/ Volvo replaced it under the warranty. Now about 530 hours on the new engine and we had the oil tested for the survey and the aluminum was 1400 on the replacement engine. We’re wondering what is making the engine go bad on the same side of the boat. Is there something that is making this happen?
Old Oct 18, 2019 | 06:20 AM
  #30
Rfelice's Avatar
Did you ever figure out what was going wrong with your engine? We are purchasing a 2008 Regal with Volvo Penta engines and we found out that the one of the engines blew after about 500 hours. Regal/ Volvo replaced it under the warranty. Now about 530 hours on the new engine and we had the oil tested for the survey and the aluminum was 1400 on the replacement engine. We’re wondering what is making the engine go bad on the same side of the boat. Is there something that is making this happen?
suki01
Penta
17
Jul 4, 2024 06:45 AM
a7abw
May 20, 2018 01:45 PM
Fifth
Jan 30, 2010 08:57 PM
clawless
Oct 30, 2009 05:31 PM
Silverstar
Jan 27, 2009 02:07 PM
