POWER STEERING LEAK
Old Jan 2, 2008 | 09:16 PM
ROBLU540's Avatar
Default POWER STEERING LEAK
I THINK I HAVE A POWER STEERING FLUID LEAK. SO MY QUESTION IS WHAT TYPE OF FLUID CAN I USE, AND HAS ANYONE ELSE EXPERIENCED THIS PROBLEM? WHERE SHOULD I LOOK, SO FAR IT LOOKS LIKE IT IS COMMING FROM ONE THE HOSESBECAUSE THEY ARE WET WITH FLUID BUT NOT SURE IF THIS IS THE SOURCE OF THE LEAK. OH YEAH ITS A 04 V70.
THANKS ROB
Old Jan 2, 2008 | 10:24 PM
99VolvoV70's Avatar
Default RE: POWER STEERING LEAK
I'm sure someone knowledgable will answer this, but I know I have seen threads on this topic. You might try searching. I vaguely remember reading a discussion about using Automatic Transmission Fluid vs Power Steering Fluid. (To answer your other question, I haven't experienced this problem.)
Old Jan 3, 2008 | 07:55 PM
Get some Vavoline synthetic fluid with sealers.
http://www.valvoline.com/pages/produ...asp?product=22
This one.
Most likely it is leaking at the return hose at the pump or at the fluid bottle bottom hose.
Old Jan 3, 2008 | 09:52 PM
samadkins29's Avatar
yea what tech said, i used that and it worked great, unfortunatly my leak was from the wrack its self, but it made it last until payday.
ROBLU540
Feb 20, 2009 07:59 PM
samadkins29
Aug 9, 2007 01:31 AM
reg
Apr 3, 2005 03:29 PM
reg
Mar 17, 2005 07:57 PM
