VOLVOs 19T TURBO?
Old Nov 20, 2009 | 02:51 PM
  #21
washdup's Avatar
Another issue: the 19T came on cars with the newer version of the Motronic engine management system better able to control the timing/fuel/boost parameters needed to safely run the 19T. The older ECUs found on 1998 and earlier cars (might be 1999) are not as able to address those parameters, which heightens the risk of engine failure when upgrading to a 19T.
Old Nov 24, 2009 | 07:26 AM
  #22
Why would anyone run the 19T on a stock tune? Is it even possible? You have to get larger injectors for the turbo and once you do injectors your supposed to get a tune.
Old Jan 29, 2010 | 06:33 AM
  #23
Why? Because people are stupid and thing all you need is the turbo and your good to go.
Is it possible? I am going to say, YES it is. Why? Because I bet for a short time it will run fine. Until you really boost it and blow a rod.
Not only should you get bigger injectors... But you should also do a full 3" mandrel bent Turboback exhaust system, FMIC & Intake upgrades and then get your tune to take into account all the things you have upgraded to take full advantage of the turbo and the other mods you did.
Old Jan 29, 2010 | 10:30 AM
  #24
I totally agree. You could run a 19T on stock everything, I would be scared to even touch the gas pedal though. I have decided that I'm going to run a 19T on my build, but that 19T is paired with larger injectors, exhaust, fmic, intake, silicone lines/hoses, and I would say most importantly with the 19T an EBC and a proper tune.
Old Jan 30, 2010 | 05:07 AM
  #25
franklin123's Avatar
I really don't want to go inside the engine just yet. i will only do bolt-ons for now.
Old Jan 31, 2010 | 02:33 PM
  #26
gilber33 please add T-Bolt clamps to your list. Regular hose clamps just wont cut it.
Old Feb 1, 2010 | 10:15 AM
  #27
You betcha, I'll be eliminating all "load bearing" worm clamps.
SilverRain
Jun 17, 2014 07:57 AM
dieselcruiserhead
Jul 17, 2013 06:27 PM
lemans24
Engine & Internal
16
Jul 26, 2008 01:05 PM
ES 3000TT
Dec 31, 2005 06:43 PM
ES 3000TT
Oct 2, 2004 02:39 PM
