Issues on my car
Old Aug 2, 2009 | 05:11 PM
  #21
VJZ's Avatar
VJZ
Still nothing.
the three port vacuum plug that I am referring to screws into the side of the bottom portion of the air box.
That was unplugged when I bought it and that plug I assume was ran to another, broken three port thing. The middle line on the correct one was plugged with a screw.
All hoses and stuff are back to normal.
I can;'t figure it out. The car still won't turn over.
Old Aug 2, 2009 | 05:27 PM
  #22
blackbrick's Avatar
plug and wire numbering
http://volvospeed.com/Repair/sparkplugs.php
Old Aug 2, 2009 | 06:16 PM
  #23
VJZ's Avatar
VJZ
Yep.
Twas the firing order.
AllData was completely different. Ghey.
Now its back to before the tune up.
One thing I never posted was that along with the car cutting out (fuel wise) it also smells like fuel, sort of rich.
Anything that tidbit helps with diagnosis?
Old Aug 2, 2009 | 08:51 PM
  #24
blackbrick's Avatar
I assume that is related to P0102 code. So it could be
1 bad or dirty MAF
2 disconnected or bad wiring to MAF
3 air leak near MAF
4 bad computer
I would try to eliminate first 3 before go to 4th.
Old Aug 3, 2009 | 12:29 AM
  #25
VJZ's Avatar
VJZ
I tested the MAF and it was fine (Unplugged while running, then dies).
As we've discussed before, like what tech has said, perhaps the FPR, fuel pump relay, or even the pump itself?
The starting issue I believe now to be the PNP switch.
I hate seeing this car just sit in the garage. Kind of depressing.
Old Aug 3, 2009 | 12:58 AM
  #26
blackbrick's Avatar
You may have multiple issues.
If pump or relay is bad you should be running lean not rich or not running at all.
Old Aug 3, 2009 | 01:10 AM
  #27
VJZ's Avatar
VJZ
We'll see how this goes.
To confirm, the Incorrect Gear Ratio code does indeed indicate a bad PNP?
After I fix that I'll worry about the fuel problem.
Timing belt is getting done Wednesday.
Old Aug 3, 2009 | 01:16 AM
  #28
blackbrick's Avatar
I agree, dealing with one problem at the time is best approach
Old Aug 3, 2009 | 01:10 PM
  #29
VJZ's Avatar
VJZ
Indeed.
I can deal with the fuel issue, because it seems to be fine after a while. Bit I want it running properly.
I just hope the PNP fixes the problem :/
Old Aug 3, 2009 | 01:22 PM
  #30
VJZ's Avatar
VJZ
Woot!
I am getting a new OEM Volvo PNP switch from a guy on VolvoSpeed!
He said he put it on his car and that was not the issue because his is a five speed.
Go ahead with it?
Old Aug 3, 2009 | 01:33 PM
  #31
Do it, wouldn't hurt, and if that's it, well then your good to go, and if that's not the issue, sell it and scratch the pnp switch off the list of possible problems.
Old Aug 3, 2009 | 03:16 PM
  #32
VJZ's Avatar
VJZ
WTF else could it be? LOL
fjkai
Jul 2, 2009 07:37 PM
wheelsup
Jan 14, 2008 12:45 PM
estrn_uro
Nov 6, 2007 09:44 PM
kaltek
Aug 11, 2005 08:17 PM
